Flat sanding surface http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=41962 |
Page 1 of 2 |
Author: | johnwalkerwaldsmith [ Mon Nov 18, 2013 12:25 am ] |
Post subject: | Flat sanding surface |
Im getting tired of running downstairs to my drum sander feed belt to sand things flat! I want to buy some thing I can have mounted to the top of my work bench. What do you guys use for a good flat sanding surface? and where did you get it? |
Author: | Rod True [ Mon Nov 18, 2013 12:32 am ] |
Post subject: | Re: Flat sanding surface |
I have a flat sanding dish 1-1/2" thick MDF, was an extra from making radius dishes. I put sandpaper on that for any flat sanding. |
Author: | johnwalkerwaldsmith [ Mon Nov 18, 2013 12:38 am ] |
Rod True wrote: I have a flat sanding dish 1-1/2" thick MDF, was an extra from making radius dishes. I put sandpaper on that for any flat sanding. Did you true it up with anything? or is mdf generally flat enough? |
Author: | martintaylor [ Mon Nov 18, 2013 12:46 am ] |
depends on how big you are talking. I have some thick tempered glass that I use for smalls. I use spray adhesive to join the paper as it has almost no effect on the flatness and I can change over to various grades really easily. |
Author: | Rod True [ Mon Nov 18, 2013 12:48 am ] |
I check it often with my straight edge. It's been highly stable over the past 6 years since it was first made. |
Author: | johnwalkerwaldsmith [ Mon Nov 18, 2013 1:13 am ] |
martintaylor wrote: depends on how big you are talking. I have some thick tempered glass that I use for smalls. I use spray adhesive to join the paper as it has almost no effect on the flatness and I can change over to various grades really easily. Im just talking about small stuff.. Where did you get your tempered glass? although rod makes me feel like i may have a solution sitting in my scrap box... Thanks for the quick replys guys! |
Author: | DennisK [ Mon Nov 18, 2013 1:25 am ] |
8x3" extra-extra-coarse DMT diamond stone, from Lee Valley ![]() It's pretty fine by wood standards (I glue directly off of it), so you might still need something with 80 grit to start. But then you don't need ultra-flat for rough work, so just your bench surface should do for that. |
Author: | Trevor Gore [ Mon Nov 18, 2013 3:44 am ] |
Have you thought about 1) a plane and/or 2) a plane? 1) Most things wood come up flatter by using a plane of suitable choice (hi/lo angle, small/large size) 2) An old flattened plane sole with sandpaper glued to it can be used on wood or non-wood jobs, either as you would use a plane or by rubbing the job on the sandpapered sole. |
Author: | B. Howard [ Mon Nov 18, 2013 5:14 am ] |
I have small pieces of granite. They are about 8"square. They were samples from a counter top company, they change their samples on a regular basis so I got them for free. I went through the pile with my straight edge and kept the winners. |
Author: | Jaybird840 [ Mon Nov 18, 2013 5:57 am ] |
+1 for granite... I have a 24"x 24" Piece that sits on top of my workbench. It usually just gives me a good flat surface to work on, but I am forever using it to sand things flat. Attachment: fretboard done.jpg
Author: | klooker [ Mon Nov 18, 2013 7:42 am ] |
I work next to a granite counter top shop. They have stacks of sink cut outs that they sell for cheap but they're expensive to ship. I have a couple of pieces that I use for flat surfaces & weights to put on top of backs/tops when joinining. Kevin Looker |
Author: | Goodin [ Mon Nov 18, 2013 8:58 am ] |
Granite, like others. I use a scrap granite window seal I found under my house. Actually I think it's marble. Anyways, It's about 20"x6"..about the perfect size for flattening necks at the fretboard mating surface, flattening soles of planes, and numerous other small sanding tasks. I use double stick tape with 80 grit on it. I also bought a piece of glass at a custom glass shop that I sit on top of it with 120 grit double sticked to it. |
Author: | Doug Balzer [ Mon Nov 18, 2013 9:49 am ] |
If you have one, the in/off feed tables of a jointer work really well. |
Author: | jfmckenna [ Mon Nov 18, 2013 10:14 am ] |
I use MDF as well, a piece large enough for 4 squares of 60 grit paper. It's great for fast rough shaping of nuts and saddles, sanding bridges flat, and a whole lot more. |
Author: | unkabob [ Mon Nov 18, 2013 11:11 am ] |
I use 80 grit removed from my sanding drum spray-glued to a ceramic tile 12"X24" for flat sanding. Bob ![]() |
Author: | Tim L [ Mon Nov 18, 2013 12:51 pm ] |
I have several granite plates, from one like Jaybirds to a 24x18x2" slab an artist friend gave me that was left over from one of his projects. The accuracy varies but all are close enough. I still don't hesitate to use the bed or table of a machine, a flat piece of cast iron, even have a 6" square x 1" chunk of steel plate. They all work. Tim |
Author: | Quine [ Mon Nov 18, 2013 1:26 pm ] |
johnwalkerwaldsmith wrote: Im getting tired of running downstairs to my drum sander feed belt to sand things flat! I want to buy some thing I can have mounted to the top of my work bench. What do you guys use for a good flat sanding surface? and where did you get it? So lemme get this straight.....you have a 2 story workshop with a drum sander?? Wish I had your problems ![]() |
Author: | johnwalkerwaldsmith [ Mon Nov 18, 2013 3:09 pm ] |
Quine wrote: johnwalkerwaldsmith wrote: Im getting tired of running downstairs to my drum sander feed belt to sand things flat! I want to buy some thing I can have mounted to the top of my work bench. What do you guys use for a good flat sanding surface? and where did you get it? So lemme get this straight.....you have a 2 story workshop with a drum sander?? Wish I had your problems ![]() no... I have a one story house with a trap door basement where all my power tools are, workbench is in my living room....hah! the way you said it just made it sound to great! had to clarify |
Author: | murrmac [ Mon Nov 18, 2013 4:15 pm ] |
Todd Stock wrote: MDF is very stable and usually very flat, but unless sealed with shellac and mounted on a flat surface, it may not stay that way. For saddles and nuts, a small square of MDF on a bench top is fine, but for fretboards and other longer components, a cheap surface plate which is properly supported is a better bet. Cheap surface plate , Todd? ...they only come along once in a lifetime,and you have to be in the right place at the right time.. (unless of course we are talking about Chinese surface plates 24" x18" (which still aren't cheap IMO)) I count myself fortunate to have scored a British made (Crown) 60"' x 36" x 6" granite surface plate some years ago, and this plate has been an absolute godsend in all sorts of ways. btw Todd, given your current "kiltic" signatures, would I be correct in assuming that you are familiar with the Mike Cross composition "The Scotsman's Kilt" ? If not, then search on Youtube ...the version by Bryan Bowers is incomparably the best ... |
Author: | emoney [ Mon Nov 18, 2013 7:14 pm ] |
If it's small pieces, you can usually pick up an End or Backsplash in granite from most of the big box lumber stores. Also, yard/garage sales and/or flea markets and look for outdoor tables as a lot of them hand a granite insert in the top. |
Author: | kfish [ Mon Nov 18, 2013 9:47 pm ] |
If you are in the Chicago area and are looking for free granite cutoffs; http://chicago.craigslist.org/wcl/zip/4140827259.html I have no connection with these folks so can't comment on the quality. Kent |
Author: | nyazzip [ Mon Nov 18, 2013 9:59 pm ] |
i got a chinese marble or granite surfacing stone awhile back and i love it. i think i got it at rockler or woodcraft; they don't seem to carry them anymore. milled to 0.001" tolerance i think, which is plenty good enough for me to get crisp bevels on my chisels, etc also: kfish, thanks for the craigslist tip, i am definitely going to check that out ! edit: or maybe it is 0.0001" tolerance, i can't recall |
Author: | Goodin [ Tue Nov 19, 2013 9:20 am ] |
murrmac wrote: I count myself fortunate to have scored a British made (Crown) 60"' x 36" x 6" granite surface plate some years ago, and this plate has been an absolute godsend in all sorts of ways. Wow, that's huge!! Must weigh a ton. Sure those dimensions are correct? |
Author: | Ed Haney [ Tue Nov 19, 2013 2:26 pm ] |
I bought a 24"x18"x3" thick granite surface plate new for $75 that is accurate to .0005" across the entire surfact (not that that much accuracy is really needed. I use it a lot. Very handy to have a reference that I know is flat for checking things (straight edges, etc.) ,sanding and clamping. I also use it as the base for my go-bar deck with 1.5" thick MDF radius dishes on top of it. I built a frame to hold it out of 2x4's at seating height with 4 legs with locking swivel casters on them. I can easily move it around. Only supported on the outsides edges by the frame. VERY heavy but does not sag ![]() |
Author: | Ed Haney [ Tue Nov 19, 2013 2:30 pm ] |
delete double post |
